I have an 85 Dodge Daytona. I also have an '88 service manual. I wanted to drain some gas out of the tank for my lawnmower. The tank is full and the car has been sitting for a year. I really don't want to run that old gas in the Daytona once I get it running. I tried to siphon it out with a hand pump but the hose wouldn't go down into the tank. After an hour of looking at the FSM I found a plug I thought I could apply 12 volts to get the fuel pump to turn on. I looked at the engine bay and found that that plug didn't exist on my 85.
I found another connector to use, though. It is the connector that goes to the fuel injectors right at the rail. Just unplug it and apply 12 volts to the black wire with the dark green stripe. Then hook the negative wire to the body somewhere.
The pump turns on and presto! the gas cometh. I don't have the battery or engine in the car right now, so cycling the fuel pump would be tricky otherwise. This worked well, so I thought I would share. It will work for an 88 as well because the FSM showed the same color wires for the fuel injector plug.
