I'm wondering if the LM can handle using the wideband as it only o2 sensor. We all know narrowand o2 arnt that accurate and with more accurate reading could make more power?
I'll be using AEM uego with the white wire on the WB going to the o2 pin on the ecu. So with the NB o2 being accurate to .7% and the WB o2 being accurate to .1% would it not tell the ecu a better AF?.:thumb:Depends on the wideband you'll be using. Some could simulate a narrowband o2 output, some can't.
LM can't tell the difference between a simulated narrowband output or a true narroband 02 sensor, and accuracy would be exactly the same, provided both are in good working condition.
LM only care about two things: richer than 14.7 and leaner than 14.7.I'll be using AEM uego with the white wire on the WB going to the o2 pin on the ecu. So with the NB o2 being accurate to .7% and the WB o2 being accurate to .1% would it not tell the ecu a better AF?.:thumb:
Fixed.LM won't be able to tell the difference between A/F 10 or 12, both are just "richer than 14.7" to the LM.
i've been runnin an AEMUEGO for years now without an 02 sensoand a LM,works greatI'm wondering if the LM can handle using the wideband as it only o2 sensor. We all know narrowand o2 arnt that accurate and with more accurate reading could make more power?
What do you mean not happy? lolThere has been a couple people here who have tried running the stock ECU off the "simulated narrowband" output of the AEM and have NOT got it to be happy.
