1 - 6 of 6 Posts
What Lines Do I Need Just To Run The Car ??? Its An 87 Sundance With The L.m. And Map Under The Kick Panel ?
Someone Said All You Need Is The Fuel Pressure Reg, Map, Baro Solenoid, One To The Throttle Body And One To The Waste Gate Can ? Any Help Would Be Great I Would Like To Use The Minimum Lines Car Will Not Use Cruise And It Will Also Get A Aftermarket Boost Gauge So I Can Elinminate Those Two But What Else ?
the map sensor vac. line must go from the intake, to the solenoid, then to the map...
as well as the wastegate vac. line...unless you run a g-valve to control your boost..
TT
hi i am having a vacum problem to i have a 2.2 incool 2 and i i have a trubo i can't find out where the outer line goes off the trubo the trubo has two outlets on it.
R.I.P Dennis Jarvis
1 - 6 of 6 Posts
