Vibration at 85mph...
438 Views 9 Replies 5 Participants Last post by  vsman77
I am getting vibration when reaching 85mph on the highway. Is anyone else having this problem?
Vaughn
1 - 10 of 10 Posts
Yeah... its called worn suspension parts old cars are notorious for that. Seriously tho I would check your hubs, Then struts/shocks, control arms tie rods etc As I am sure you have already checked your axles and have had your alignment done?
I do need an alignment and swaybar bushings. Could they be the cause?
yeah... that solved most of my problems in my 86' shelby charger
Check the inner CV's....that caused my vibration...
balance wheels? you would be suprised how much difference it makes
In my experience it's usually an unbalanced wheel or a damaged tire.
The axles were replaced a little while ago. I think the tires were balanced, but not totally sure.
wheel weights can fly off in a mile, a slipped belt, choppy, or flatsided tire could do it too
  • Like
Reactions: 1
I will check those out...THANKS :)
1 - 10 of 10 Posts
