Hi all, new to the community, just picked up my first L-Body car, an '85 Omni with a VNT engine among other mods. Just caught my fancy and I couldn't pass it up, so I'm still learning quite a bit about the car.
Long story short: On the way home from purchase, it died on me. Bit of quick diagnostics, the upgraded melling oil pump gear and distrubutor drive gear on the intermediate shaft ate each other. Got it all back together and she started and ran fine on the first crank. This included a new oil pump, new pickup, intermediate shaft, intermediate shaft bearings and seal. Couldn't have been happier.
Noticed a small oil leak, so I thought the pan needed to get tightened a bit. Did that, then on the next start it immediately blew the oil filter gasket out. Behaving just like the drain-back valve froze shut, so took that apart, and it looked and operated fine, so just cleaned and reinstalled with a new filter/ oil. Same thing. Started, and immediately blew the gasket and was puking oil out the filter seal/ distributor base (shortest distance to pump outlet.)
Pulled the oil pump and inspected, pulled the intermediate shaft to check bearing alignment and seat, pulled the check valve again and everything looks absolutely perfect, no visible blockages anywhere. A friend thinks I spun a main, but even without knowing the oil flow diagram, I can't believe believe one main would block 100% of oil flow.
Seems likely to me it's positive crankcase pressure since it blows immediately when it fires. Crank without fuel/ spark and it doesn't leak oil or seem to be building oil pressure anywhere, but where would it be coming from? Can't be blow-by, it's instantaneous, and it wouldn't be boost coming back through an improperly timed PCV since it's at idle, Block is intact, piston's are intact...
I'm stumped. Any ideas?
