1 - 20 of 58 Posts
Does anyone know what the voltage to charge air temperature table is?
I have just purchased an LM-3 AuxBox from Innovate Motorsports and I want to record the charge air temps from my sensor but I don't know what the voltage conversion table is.
Also does anyone have the EGT conversion table as well??
Thanks,
· Administrator
0 deg = 4.70 volts
20 deg = 4.47
40 deg = 4.11
60 deg = 3.67
80 deg = 3.08
100 deg = 2.51
120 deg = 1.97
140 deg = 1.52
160 deg = 1.17
180 deg = .86
200 deg = .65
220 deg =.48
240 deg = .35
260 deg = .28
Cannot help with EGT's
Thanks, I've been looking all over for this.
Will this work for a 1987 Shelby GLHS Charger sensor? I'm assuming they are they same sensor for most of the dodge/chryslers, but I just want to make sure.
· Administrator
That came from a Chrysler Training Manual and the manual does not discuss individual vehicles only the theory of operation,evolution and general diagnostics of systems up to 1990 so that chart will be accurate for all vehicles using an Air Charge Temp Sensor.
· Administrator
Coolant Temp Sensor Response Chart
110 degs = 4.20 volts
120 = 4.00
130 = 3.77
140 = 3.60
150 = 3.40
160 = 3.20
170 = 3.02
180 = 2.80
190 = 2.60
200 = 2.40
210 = 2.20
220 = 2.00
230 = 1.80
240 = 1.62
250 = 1.45
Temperature to Resistance
32 degs = 30 - 35 K ohms
77 degs = 9 - 11 K ohms
212 degs = 640 - 720 ohms
· Administrator
Someone should make those charts a sticky so I do not have to retype them when someone else needs the info.
Glad I could be of help. :thumb:
· Premium Member
YES! This is the information that I have been searching and searching for! I don't have a working TII charge air temp sensor to test, but I've been trying to figure out if the Neon charge air temp sensor is compatible with the old turbo Dodge sensor. It definitely appears to be!
Ok Naj thanks,
how about the 3bar and 2 bar sensors?
tps etc? please.
· Administrator
Map Sensor Response Chart Turbocharged
Pressure in Inches/HG to Voltage
24.01HG/.43V
18.11HG/.93V
12.20HG/1.42V
6.30HG/1.92V
.39HG/2.41V
2.71PSIG/2.91V
5.61PSIG/3.41V
8.51PSIG/3.90V
11.31PSIG/4.40V
14.31PSIG/4.90V
TPS Response Chart
Throttle Position in Degrees to Increase of Minimum TPS Volts
Closed Throttle
10 DEGS/0.00V
20 DEGS/0.38V
30 DEGS/0.75V
Half Throttle
45 DEGS/1.31V
58 DEGS/1.80V (1)
75 DEGS/2.43V (2)
Wide Open Throttle
90 DEGS/3.00V
(1) The computer will usually consider an increase of 1.80 volts or more over the minimum TPS voltage to be WOT.
(2)2.43 volts above the minimum TPS voltage during cranking will cause the computer to recognize Clear Flood request shutting off all fuel delivery.
GM part 16040749 (discontinued) 3 Bar map 3bar measured voltage with cheap digital voltmeter and used the compressor regulator to set pressure . Btw, pin a is ground b is signal and c is 5v. I do believe on the newer sensors PINS A and B are switched.
20hg vac .5
Atmosphere 1.59 (currently 30.13 in per weather.com) :D
under boost- PSI
5 1.98
10 2.8
15 3.10
20 3.64
25 4.25
28 4.63
32 4.99
Enjoy!
Voltage table for k type thermocouple F
0.000000, 32
0.000397, 50
0.000798, 68
0.001203, 86
0.001612, 104
0.002023, 122
0.002436, 140
0.002851, 158
0.003267, 176
0.003682, 194
0.004096, 212
0.004509, 230
0.004920, 248
0.005328, 266
0.005735, 284
0.006138, 302
0.006540, 320
0.006941, 338
0.007340, 356
0.007739, 374
0.008138, 392
0.008539, 410
0.008940, 428
0.009343, 446
0.009747, 464
0.010153, 482
0.010561, 500
0.010971, 518
0.011382, 536
0.011795, 554
0.012209, 572
0.012624, 590
0.013040, 608
0.013457, 626
0.013874, 644
0.014293, 662
0.014713, 680
0.015133, 698
0.015554, 716
0.015975, 734
0.016397, 752
0.016820, 770
0.017243, 788
0.017667, 806
0.018091, 824
0.018516, 842
0.018941, 860
0.019366, 878
0.019792, 896
0.020218, 914
0.020644, 932
0.021071, 950
0.021497, 968
0.021924, 986
0.022350, 1004
0.022776, 1022
0.023203, 1040
0.023629, 1058
0.024055, 1076
0.024480, 1094
0.024905, 1112
0.025330, 1130
0.025755, 1148
0.026179, 1166
0.026602, 1184
0.027025, 1202
0.027447, 1220
0.027869, 1238
0.028289, 1256
0.028710, 1274
0.029129, 1292
0.029548, 1310
0.029965, 1328
0.030382, 1346
0.030798, 1364
0.031213, 1382
0.031628, 1400
0.032041, 1418
0.032453, 1436
0.032865, 1454
0.033275, 1472
0.033685, 1490
0.034093, 1508
0.034501, 1526
0.034908, 1544
0.035313, 1562
0.035718, 1580
0.036121, 1598
0.036524, 1616
0.036925, 1634
0.037326, 1652
0.037725, 1670
0.038124, 1688
0.038522, 1706
0.038918, 1724
0.039314, 1742
0.039708, 1760
0.040101, 1778
0.040494, 1796
0.040885, 1814
0.041276, 1832
0.041665, 1850
0.042053, 1868
0.042440, 1886
0.042826, 1904
0.043211, 1922
0.043595, 1940
0.043978, 1958
0.044359, 1976
0.044740, 1994
0.045119, 2012
TPS Response Chart
Closed Throttle
10 DEGS/0.00V
20 DEGS/0.38V
30 DEGS/0.75V
Half Throttle
45 DEGS/1.31V
58 DEGS/1.80V (1)
75 DEGS/2.43V (2)
Wide Open Throttle
90 DEGS/3.00V
Is this data the same for the N/A 3.0 v6?
· Administrator
It should be, all 3 wire variable resistor sensors (Map and TPS) operate on the same 5 volt reference.The only exceptions to this would be a N/A and Turbo Map as the Turbo has to read above atmospheric(boost).Changing from manufacturer to manufactuer the voltage reading may be different as far as what thier controller parameters are set to see as normal but the MAP and TPS will still read 0- 5volts.
The voltage tables posted are for Chrysler Vehicles.When you check TPS you are looking for excessivly low or high readings with the throttle closed(will set a code) or dead spots when you sweep the TPS.
Ok, thanks. I was just confused about this since my data-cd says the TPS should output 1-5volts, when this voltage table says 0-3volts. But i would believe this info to be correct since i get like a bit over 3 volts max on my sensor.
1 - 20 of 58 Posts
