1 - 5 of 5 Posts
I am needing the pan that goes under the louver on the Turbo Buldge Hood on a Charger. I have the Hood, all Brackets, louver, and it is SLICK. Now I need the pan to stop all the water from dumping on the Carb.
Can you help.
If you have a carb or T2 motor it will hit, that's why it was cut off in the 1st place. Mine has a thin piece of plastic under the grid that I made to seal the hole.
Thanks. This is your old hood Rare Ram. I finally got it all worked and painted, installed and it looks darn good. Thanks Again
Max
1 - 5 of 5 Posts
