in normal operation is the wastegate solenoid an all-open/all-closed device only, or, does it have some partial settings (ie: partly open, partly closed, etc)?
thanks.
thanks.
correct, and correctMarcus86GLHS said:if you're running a manual boost controller, or a grainger valve, i think you dont need this orifice anymore. you could leave it in, wouldnt necessarily hurt.
i removed the orifice and tested the boost behavior w/o it: boost is very sluggish to build, my thoughts are that this is owing to the fact that too much pressure (signal) is reaching the can from the solenoid causing more puck movement (unmodulated).
