Well, while it's apart
2561 Views 29 Replies 13 Participants Last post by  Fox
The 2.5 in my Acclaim is getting the head pulled to replace the head gasket.
Any ideas for mods while i have the head off?
I'm gonna wrap the exhaust manifold and do a gasket match so far... gimmie some more ideas!!!!
1 - 20 of 30 Posts
well the best idea you can go for is to get a mopar head gasket the felpro are known to go bad, and you dont have to gasket match the ports just clean them up and smooth them and it will make a differnce
well crap... got the part number for the Mopar gasket? I was looking at a fel pro "super seal" or something like that
I would have the valve cover painted or powder coated a really girly color like pink or purple...but that's just me. And that doesn't really qualify as a mod, does it?
if that was a print-a-seal gasket by fel pro it's a dam fine gasket and it won't rot like a mopar one around the water passages ( print-a-seal is a grey coloured gasket with silicone bead seals)
the fel pro ya wanna stay away from is the blue coloured "perma torque"
yeah i think it was a permatorque, i'll ask my boss to order one from the dealer he lives by
and painting the valve cover a girly color? do you think i'm trying to rice out my car???
Is this a TBI car?
lol the G33K is a lady,
Yeah it's a TBI car (94 Acclaim). I ordered the gasket today from the local dealer, got a new water pump, felpro head bolts, intake and exhaust gaskets, magnetic drain plug...
I think I'm going to change out the E3 plugs for a set of NGK Platinums.... or if you guys have another suggestion I'm open for it. The car has an Accel coil on it with Taylor wires and a K&N filter so far. I plan on doing some very minor porting on the head while it's off and after some research I've decided not to wrap the exhaust manifold.
Since I'm not wrapping the manifold, is there any shielding that can be made or that is sold to maybe keep exhaust heat away from the intake? I plan on blocking the cooling lines that go to the intake for the sake of a denser intake charge, and later down the road I'd like to put in my own cold-air ductwork.
Other later plans for the car involve new wheels, a small and tasteful wing (no six foot tall fake carbon fiber BS, more like 03 OEM stratus/taurus), bucket seats inside with a Getrag A555 swap, custom center console, pillar mounted digital gauges, a tach, and..... heck, i'm not sure but i'm sure i'll come up with more stuff
In the meantime it's time to go pull the head so I can have it milled tomorrow!
1st setup the cam according to the book , then advance the cam (clockwise) 1 tooth , smoother idle and better power. 2nd score a computer from a minivan with the same motor , if i'm not mistaken the mini's got a slightly more agressive timing curve for the xtra weight ? someone will surely let me know if I'm wrong. otherwise porting the water pump housing would be a nice bonus for xtra HP
what do i need to port on the waterpump?
after pulling the head and disassembling it i noticed that there's a TON of aluminum to remove if i want to gasket match the intake ports... something tells me that there's a waterjacket there... anybody know?
Heavens no! But I'm a girl and we like things in pink and purple!
I was totally just kidding, by the way!
Well since you got the head why not go turbo? just buy a complete TI intake with injectors/tb/sensors, wiring. Then order a top end gasket kit that way you have all new gaskets on your top end. Buy a cheap turbo head (under 75 plus shipping for complete ones in the FS section, I even have one posted),buy a turbo LM, buy a cheap mitsu in good condition WITH the swingvalve (at the most 75 shipped), buy an exh mani (also super cheap) and a downpipe and you should be good to go. If you spent some time and ported the exh/int manis, SV, turbine/compressor housings, you should make some nice power compared to what you have now. Just my opnion, its not expensive at all, and since you have the head off already, you already have about half the work done.
Uh oh. Hold on to your wallet.
I've discovered two absolutes in my life.
Stories that start off with "We were drinking some beers..." usually end with someone doing something ...unwise.
Stories that start off with "While I'm in there..." usually end up with a significantly lighter wallet.
I wish I had all that, but I'm looking to get back on the road by the end of the weekend lol, not having a car is starting to suck bad
You want to make more power?
Eliminate the coolant lines to the bottom of the intake manifold. Open up the TB hole in the intake manifold all the way out close to the flange, and then make a throttle body spacer. Shave the head for a compression bump.
Those are the only things i would do that are easier with the head off. I definitely wouldnt advance the cam a whole tooth (9 degrees). That doesnt make more power, it makes slightly more low end torque and a lot less higher-rpm power. I wouldnt bother porting anything because the restriction is not the runners or the ports, it's the throttle body itself.
You can get a tbi up to 115-120hp with basic mods like manifold coolant line delete, 180 thermo, exhaust, a little more base timing, modded airbox, etc.
But you will not be able to gain a WHOLE lot of power unless you come up with a less restrictive throttle body, and a way to tune it.
what about running the Chevy 300 CFM TBI and tuning with fuel pressure. Not being turbo fuel pressure should get close enough.
A ported stock valve head with more fuel pressure would add a lot of torque, drastically increasing the average flow of the head. Stock the 782 has sad low lift flow, the worst of all the 8v heads.
dont do ut own cold air duct work the engineers at the factory get paid hundreds of thousands to make the parts perfectly match the cars they are attached to and im sure they did a better job at it then using toilet piping as cold air and if u dont hook ur pvc system upright you will eventually destroy ur engine, everything else sounds nice but trust me dont do it, and if u must do it DO IT RIGHT!!!!!! dont use breather caps for pvc or ur also taking out half the pvc process
The factory tbi intake manifold and air box are designed to keep the throttle blade from freezing closed and to keep the fuel atomized in the manifold in extremely cold weather, at the expense of flow/hp.
Sure, they did a good job of that, i guess. But you're giving up airflow 99-100% of the time to protect against something that, for a lot of people, happens very rarely or never (i live in south texas, so NEVER).
There's nothing wrong with modding the airbox. You can use any kind of ducting you want to route air to the motor.
When i was modding a tbi i noticed that if you take the top part (the fuel part) off of the tbi throttle body, it will actually sit on the lip of a mfi tb (t1 or v6) and fit pretty well. If you brazed or jb welded it on and then incorporated the different bolt pattern into a throttle body spacer, it might be an easy way to get a bigger TB on a tbi.
1 - 20 of 30 Posts
