What kind of fuel are you going to be running. That *might* have an impact on how well the bottom end deals with the intended power goal. As stated the bedplate it the part that shows its weakness first. With correct and good bracing 1000hp can be put through it, BUT, I'd be willing to bet on a filled block.
If you are talking about the 2.4 out of the SRT-4 Neon, then that is a cast iron block. No sleeves to worry about!
I don't know of any issues with the bores on them, however that's not to say it can't happen. We've had a few instances of people with 2.2/2.4's crack them at the top, but that's only been a few cases and above 500whp. Thus far posting the block in that area has solved the issue without loosing drivabilility from what I've read here.
