On a whim I decided to check the part number on my SMEC for my '89 Daytona Shelby T2 5-speed. Here's the details of this ECU...
The previous owner had 2 turbo cars. 1 was this Daytona and the other was an '89 Voyager. The Voyager had an engine swap from an '88 Shelby Z, along with ECU. That '88 ECU got swapped with the one in my Daytona (now my car, then still his) at some point and was never swapped back. So my car should have an '88 T2 SMEC. Great.
Here's the issue. The part number on the casing is 5234948 which comes up in 2 different places as an '89 TBI 5-speed minivan SMEC. Ok, that matches his old van so the casings got swapped. Opened up the case and the part number inside says 5227794 which I looked up on AutoECMs.com and they claim it's for an '89 2.5 LeBaron M/T. So, I'm wondering what the hell it actually is. My car seems to run fine as far as I can tell, aside from being a little rich at idle. Runs just fine and pulls like a stock T2 should. And it has the code for an air charge temp sensor because at some point the sensor went bad and threw a fault code for it. So what is this computer really? Is the part number listed anywhere else inside the case?
