... because I'm confused at this point. I thought it was the Baro-read solenoid, but I've replaced that and traced the wires and the code will not go away. I had a technician put it on a Chrysler scan tool and it said part throttle lock solenoid, but isn't that only for cars equipped with a lockup converter? Evidence would seem to point to it being a bad baro-read solenoid because intermittently I'm getting MAP sensor hiccups (4 different Mopar MAP sensors do the exact same thing, goes into limp mode and throws a 13 which lasts for a minute or 2 and then goes away). If the Baro-read isn't giving the MAP a pressure feed when it's supposed to it could cause this I suspect. The vacuum lines are all in excellent shape. The car pulls almost 20 vacuum. This 37 has been there since I bought the car over 4 years ago and I've since installed a different engine and used a different computer along the way. Any thoughts on what could be going on here?
Car is a 90 Daytona Shelby, 2.5 T1 auto (only modification is a factory intercooler with 1G BOV setup and a grainger valve, but it was having this problem long before any of those went in).
