yeah sounds like its not rightAt Idle and under boost? mine idles at 52 and at boost, goes up to 78ish...
no he's stock, trying to work bugs outYou're boosting at 23psi?
yes, thats exactly right. I got under the car tonight because the fuel pump is no longer priming... and while there is power going to the pump, the new pump is no longer working. I will go out tomorrow and purchase another gas can (as the tank is topp'd off) and drain/pull the new tank/pump that I just installed to take the pump out and verify that it is working/notworking.no he's stock, trying to work bugs out
last I knew he's got some of the vac lines figured out(was overboosting), but said it now boosts to 11 then falls on its face and boost drops.
So we can say for sure that its prob pig rich, but something else may be droping the boost also, like timing being pulled?
Its a vac line though not boost only source correct??55 PSI at idle and 1:1 gain while under boost. (i.e.: 11 PSI boost + 55PSI = 66PSI fuel pressure @ 11 PSI turbo boost)
18 inches or further from the turbo exit.OK...
Thanks for picking up my question.
Ok then,,I'm an Old guy from Old School
What and where do I ,,use,,get,,and install this wideband??
THANKS
