K , a roller cam has a blunter , more rounded tip on the lobe - this allows the roller on the follower to stay on the cam
because the roller cam is rounder , the sides or ramps to the tip of the lobe will be more full bodyed - thus giving more lift as the roller aproaches the tip (ie the cam is wider at this part)
the slider is more pointy
roller cams are also hardened steel - this is why they don't wear so quickly
