the point was that the OS valves werent needed UNLESS you have the rest of the engine work.. i.e. the ported manis, bigger turbo etc
so based on what you have written, then I think it would be good to inve$t in your head
AT MINIMUM
a good 5 angle (or radius) valve job, the SS 36.8mm exh valves, and an hour or so of mild port cleanup 'gasket match' to mate with your ported exh and intake manis
if you have the $$ - OS intake valves too
then all you should need is a good IC and of course the calibration and fuel to support it - and 300 Hp shouldnt be too tough
my swirl head has:
fresh 5-angle valve job and decking
36.8mm FWDperf SS exh valves
PT lifter/3.3 conicals/GM retainers
91 TBI roller cam
moparzrule ported (then coated) exh mani
ported intake 1-piece mani ports, head ports
minor deshrouding 'smooth sharp corners' in the CC & Singh grooves
ported inlet and outlet TII comp housing
ported & coated 0.48 turb housing
ported & coated 2.5" SV
2.5" DP & 3" FWD mandrel system, no cat or muff
SRT/4 FMIC
PS some builders here are starting with the new 200$ head castings.. if you're gonna put time and $$ into a head then maybe its best to start with a nice new one since decent used heads (uncracked) are getting HARD to find
hom much $ you got ?
