Have a few K based 84 Lebarons that I have been working on lately.
Between the 2, I've been able to sort one out and determine that the LM in the 2nd one has a Bad AIS circuit.
Both LM's look like they have been replaced and also look the same, silver painted but no labels.
My first thought for long term dependability is;
What is the newest straight swap in E/C harness and ECU that I could upgrade these to?
The K based models went to 89ish? Is there a chance the dash-back wiring remained the same through most of those years?
At the very least, I would think that 84-86/87 would have remained the same and could swap the e/C harness and LM directly in?
Anyone with any info or experience in having done this would be Great to hear from you.
On the flip side, now that most of it is sorted out, I could just replace the 84 turbo LM in the 2nd Lebaron and see how things go.
When I search, I see a lot of these out there, from Rockauto to ebay. Can anyone with 84 Turbo LM recommend one from another?
Also, how many 84 Turbo LM's are there? Rockauto only lists 1, but doing some research I've found that most say there are at least 2, Some believe there are many depending on vehicle (like later years) while others say they are indeed, all the same.
Can anyone confirm?
Can anyone confirm?
