I'm about to put down my 85 SC and start tearing apart. I'm wanting to do a full TII conversion (I have 87 TII 2 piece intake, turbo, exhaust and distributor so far.) I'm looking at going the Megasquirt route to replace the electronics. I have no experience with megasquirt and I'm curious as to which board and components I would need to build it to what I want it to be.
Ok thanks! I have another question too. I've seen that coil-on-plug can possibly work on the 2.2L with megasquirt. I just want to know if anyone has had experience with this and if there's any noticeable gains that make it worth the trouble.
there is only 1 board avaliable- v3 is the current board.
you want the MSIII kit and a peak and hold injector driver board from J&B performance- best way to run the low impedance injectors our cars have. everytihng else you will need comes in the MSIII kit.
i reccomend starting off with the stock ign coil setup, you can always change it out later
to make full use of all the features you MUST run a wideband O2- the LC-1 is a perfect match.
