1 - 20 of 40 Posts
961 kbps with my internet privacy
1026 kbps without internet privacy
That's today, this minute....you never know about my Cox Cable, it varies greatly! }(
But, I must admit MOST of the time, it's better than my old dial-up. ;)
1382 here at work. Do I win a prize for having the highest number so far? ;)
Nevermind, I see now that PTCruzr already beat me! LOL
Bandwidth Speeds
B U S I N E S S S E R V I C E S C H A R T
Bandwidth Service Speed Description and Approximate Costs / Price
DSL
128 Kbps-1.5 Mbps 128Kbps to 1.5 Mbps downstream. 64Kbps to 1.5 Mbps upstream. Consumer class is approx. $40-$50/month. Business class is approx. $90-$400/month, depending on bandwidth speed required. FIND SERVICE
Fractional T1
128 Kbps-1.0 Mbps 128 Kbps to 1.0 Mbps T1 speed with some of the 24-64 Kbps channels turned off. Prices are approx. $220-$500/month, depending on bandwidth speed required. FIND SERVICE
T1 / DS1
1.544 Mbps 1.544 Mbps digital circuit. Can be dedicated internet access, point-to-point or integrated. Prices are approx. $520-1100/month + local loop + set up costs. FIND SERVICE
Frame Relay 56Kbps & Up 56 Kbps & Up. Prices vary greatly depending on bandwidth speeds required. FIND SERVICE
E1 Europe 2.048 Mbps European equivalent of the T1. Prices vary depending on service and location. FIND SERVICE
Fractional T3 3 Mbps-44.736 Mbps 3 Mbps to 44.736 Mbps basic T3 with some of the 67-264 Kbps channels turned off. Prices are approx. $3000-$5000/month, depending on bandwidth speed required. FIND SERVICE
T3 / DS3 44.736 Mbps 44.736 Mbps digital circuit. Can be dedicated internet access, point-to-point or integrated. Prices are approx. $5000-15,000/month + local loop + set up costs. FIND SERVICE
E3 Europe 34.368 Mbps European equivalent of T3. Carries 16 E-1 signals. Prices vary depending on service and location. FIND SERVICE
OC1 51.84 Mbps 51.84 Mbps optical fiber sometimes called SONET. Uses ATM Switches (as do ALL OC-x). Prices are approx. $10,000-20,000/month + local loop + set up costs. FIND SERVICE
OC3 155.52 Mbps 155.52 Mbps optical fiber sometimes called SONET. Uses ATM Switches. Prices are approx. $30,000-50,000/month + local loop + set up costs. FIND SERVICE
OC12 622.08 Mbps 622.08 Mbps optical fiber sometimes called SONET. Uses ATM Switches. Prices are approx. $80,000-100,000/month + local loop + set up costs. FIND SERVICE
OC24 1.244 Gbps 1.244 Gbps optical fiber sometimes called SONET. Uses ATM Switches. Prices over $100,000/month + local loop + set up costs. FIND SERVICE
OC48 2.488 Gbps 2.488 Gbps optical fiber sometimes called SONET. Uses ATM Switches. Prices into the $100,000's/month + local loop + set up costs. FIND SERVICE
OC192 9.6 Gbps 9.6 Gbps optical fiber sometimes called SONET. Uses ATM Switches. Costs are extremely high. FIND SERVICE
OC255 13.21 Gbps 13.21 Gbps optical fiber sometimes called SONET. Uses ATM Switches. Costs are extremely high. FIND SERVICE
1005
1427 Kbps - Cable baby!!! :)
1 - 20 of 40 Posts
