Thats the PCV valve. Mine goes from that to the stock air box. However mine is a T1 w/o intercooler. But thats probably where yours goes too.if you look right beside there the Throttle Cable is ...theres a yellowish thing...The bottom of that.
+1, that is what it is, there should be a hose hook up spot on the air box that goes onto it. It is something that a lot of people use a different style of air filter and just get rid of the air box. That is what I did, and the liquid coming out is oil that did not get separated out of the air before hitting the PCV system.Thats the PCV valve. Mine goes from that to the stock air box. However mine is a T1 w/o intercooler. But thats probably where yours goes too
It could cause a issue with crankcase pressure, making your dipstick shoot out hitting the hood. A catchcan would be much better or you could get a piece 3"(in length, not sure what the diameter is inside the hole) straight pipe drill a hole into the pipe, and weld a nipple onto the 3", then connect the stock tube to the new 3" pipe with a fuel line and have a working PCV system.if I put a little filter like you guys have ...would that eliminate my little line problem?
