1 - 6 of 6 Posts
88 Daytona Shelby Z
Hey all,
Ended up completely tearing down my 2.2T Engine. Was hoping I can get some insight on what oil pump to get? Should I just get the stock replacement melling oil pump?
My advice is tear down your old pump and inspect. If it is in good shape, clean thoroughly and reuse it. They don't wear out like many other engines. Might not be a bad idea to buy a new pickup, they are sometimes difficult to clean and they are inexpensive.
I personally prefer the aluminum case OEM pumps to the Melling cast iron pumps. If you do happen to find some NOS Mopar pumps and buy one, tear that one down and inspect carefully. I've bought a half dozen or so over the years and they had rust, died up assembly oil, casting flash inside pump, and some didn't turn very smooth until they were gone through.
I would also port match the block to the oil pump. That is worth a few free horsepower. You will find quite a bad mismatch there.
88 Daytona Shelby Z
I appreciate that. Going to check my oil pump and see how it is
I couldn't agree more, good advice !!
PS: Below is a post by Chrysler Engineer 5 digits, RIP Ken.
Intermediate Shaft / Oil Pump Indexing
For those who have ever had intermediate shaft or oil pump gear devastation, there is a method to improve gear meshing and component longevity.
As much as we'd like to believe that these components are precision machined to strict standards, they unfortunately are mass produced components with a wide quality acceptance band.
This means that the journal, gear tip, and tooth cutting processes for both components in addition to oil pump gear centering on the shaft and the distributor hole machining in the block can all amount to a noticeable uneven mesh, between the components.
This can be observed during the engine assembly process as variation in the rotating effort required to turn the intermediate shaft sprocket upon installation in the block.
This is typically caused when 'minor' non-concentric high spots on the oil pump gear are aligned with high spots on the intermediate shaft.
Although, there are a few easy steps to reduce the chance of component failure and a catastrophic event should either gear shear and cause a total loss of oil pressure.
1. With the oil pump installed, Loc-tite on the oil pump attachment bolts, and the oil pump attachment bolts near snug; install the intermediate shaft
2. Rotate the oil pump housing in its mounted position to realize how much the oil pump housing can be turned to the left and right, while visually noting travel relative to the mounting bolts
3. With the level of travel determined, clock the oil pump as close to the center position that was determined by the previous step
4. Torque the oil pump attachment bolts, per the manufacturer's recommended specification
NOTE: The previous steps have minimized the chance that the oil pump is preloaded to one side of the engine block distributor/oil-pump hole because the oil pump mounting flange surface is not always 'true' to the oil pump center-line.
5. Install the intermediate shaft retaining cover without the anaerobic sealant and lightly tighten the bolts that hold the cover in place
6. With the intermediate shaft key in place, install intermediate shaft pulley
7. Rotate the shaft by turning the pulley while noting the consistency in rotating effort, throughout several rotations
If the rotating effort is not smooth and/or consistent throughout several rotations, proceed to step 8, otherwise proceed to step 9.
NOTE: If the following steps are repeated numerous times without improvement, thoroughly inspect each component for obvious signs of significant manufacturing defect and replace as needed.
8. Re-clocking the intermediate shaft
Remove the intermediate shaft pulley
Remove the intermediate shaft cover
Note or index the pulleys/shafts current position
Remove the intermediate shaft, re-clock the shaft to one/same direction, by 90 degrees
Reinstall the intermediate shaft
Return to Step 5
9. Remove the pulley, intermediate shaft retaining cover bolts, and cover
10. Complete the final installation of the intermediate shaft cover and pulley hardware per the manufacturer's recommended specifications
The above process can provide the best possible component mesh and gear loading by improving awareness to minor manufacturing variation, aligning those variations in a manner that minimizes excessive component loading, and minimize the resulting wear.
GLHS 60 and 4L-Bodies...I also appreciate the oil pump and intermediate shaft info, both were perfect looking condition on teardown, and meshed perfectly before removal (I did the teardown, inspection and initial ck. Of all clearances before removal, so know it was all moving freely and smoothly, and ok when removed (except all rings were within 1/8" of all rings on number 1 piston clocked in a straight line), has been cleaned and line bored already was not off by much at all, and will be clean decked, bored and honed to .020 over as soon as pistons are received and measured, but very nice to have that clocking info and procedure for intermediate shaft to oil pump gear ck, and the port mating of the oil pump.
Appreciate that info guys, owned and raced the car since 93' (Mom bought it new in Feb 85', we bought it from her), but this is first actual teardown, machining, balancing, assembly, of a 2.2L Chrysler for me I personally only had the head off once before to inspect it and practice a mock teardown in 95' and only had it off an hr. (Cc'd the chambers), changed the cam, and dialed it in, put it back together to ck. My time to button up when not under the NHRA gun, to race it the next morning after a class win. Eventually, I will face it, and practice makes perfect.
So, it is really nice to have the info, tips and tricks here as I get back to where I was last in 97' only much improved, and while I only type to thank, ask questions, or have input, rest assured I am reading, soaking in all your previously posted knowledge and advice that applies to my particular combo.
I priory raced big block 60's and 70's Mopar Muscle cars in the 70's through early 90's so all my Mopar engine building experience was 340's, 383's, 440's and 2 426 wedge engines, a whole lot of helping friends and family with Dodge Colts, chevy's of all kinds, ford's, and others, but not until nowadays mid 80' s Chrysler (until they reduced my horsepower rating to where it belonged 11 HP less, and 275 lbs. Lighter would I spend the cash to do the improves that cost a bunch.
They did, family raised and gone, now we're doing it. So, learning a lot more again.
1 - 6 of 6 Posts
