1 - 6 of 6 Posts
Ok there are 2 different plugs on my a555--one rubber near the bottom, and one threaded one towards the top. Which one is the fluid supposed to filled to?
L
Guest
Fill to the bottom of the rubber plug on the stamped steel cover on the drivers side of the car. It should be the only rubber plug on the cover.
L
Guest
Easy fix,pull the plug untill it stop comming out(on level ground)and you will be good to go:thumb:
The vent is located on the top of the end bearing plate on the 555. This is located between the case and the steel or Moly plate and the vent points up and can be seen just behind the transmission mount.
Cliff Ramsdell
The Transmission Authority
For all your 5 speed and 3 speed auto needs
[email protected]
'86 GLHS 210 Shelby Roll cage and Posi unit. Cliff's, Home of the TIII Wagon
Mopartek
This may be the culprit to my oil leak. Do you know where the vent is located on the 555?
1 - 6 of 6 Posts
