1 - 5 of 5 Posts
Its because the thread has pictures that are too big to fit on the screen :thumb:
I thought that was the reason. Maybe there is a way for Rick to limit the size of the picture. I like to see pictures of diffrent setups but have to scroll back and forth reading about it almost makes it not worth it.
http://www.turbododge.com/forums/f11/f48/143263-2-4l-swap-into-91-daytona-4.html#post1194574
This is not the only thread that does this but it's just an example. The thread doesn't fit and I have to use the scroll bar at the bottom to see the whole thread. My screen resolution is 1024x768. I have tried adjusting it and nothing worked. It's the same problem wether I use IE or Firefox.
i would guess because the hot linked pictures are wider than your screen permits.
I believe those are 1280x960.
I will see what can be done.
I appreciate that.
BTW to double check I just changed my setttings to 1280x1024 and I still have the scroll bar.
1 - 5 of 5 Posts
