181 - 200 of 212 Posts
anyone heard of the lancia delta integrale hf / evo?? look it up.....2.o turbo awd the tourqe favors the rear tires lookes like the baddest l-body youve ever seen(youtube it!)
Ahem, excuse me. Kinda new here but I've been a Mopar tech for 10 years. Has anyone seen the underside of an LH body? Look at the back end of a 42LE, where the transfer gears are. I've always thought that would make the perfect place for an adapter housing of some sort to send a driveshaft rearward. Anybody with me on this? Then just twin turbo a 3.5L :)
still you can find them online under 10,000euro in ready to go condition if i get the chance to move over seas ill be lookin for one!
find one online first then as somebody to check it for u and then go to buy it. finding an integrale in good condition is tricky task.
my friend has one in peaces (probably everything is there but he have no time and money to rebuild it) in martini colours!
if he decide to do something about it i'll let u know
RIP
Yup, Definitely thought of this option myself. In fact, the '01 and later Caravan rear with the viscous coupler would work quite well in this setup for a street vehicle as the rear was designed to work with the 3.42 gear ratio available on the 42LE. And, if it weren't for the unequal length front axles on the 42LE setup we'd almost have asymmetrical AWD like a subie.
Would be a sweet setup on an old A-body muscle car.
Carlos
Bringing a post back from the dead...
When it come time to retire my stealth there are 2 thing si woul dlike to experiment with...
1) dropping the stealths turbo motor into my daytona (single turbo converon) with a stock style FWD trans along with the stealths electronics. in theory, the steath stock set up has 300hp/310tq to the crank on 6-8psi in a car that weighs almost 4000lbs. Now my stealth run 9.00 flat with 1.900 60's. swapping that motor and electronics into a car that weights around 3000lbs and simply put the car will go faster.
2) Install the complete stealth drive train and suspention so I can run the AWD. Fab up mounts to bolt into the rear sub frame and also what would be needed to mount the stealth motor/trans up front. Also working with the stealth electronics.
This would elmenate the tracton issues as well as give you the option to have all-wheel steering. when it comes to the motor they can handle (apperntly) up to 600AWHP on a stock tall block. and if you really wanted to get into it you can get headers and other supporting mods. Also AEM makes a plug-and-play stand alone computer for the stealth electronics as well.
I think a daytona with a stealth/3000gt drive train has potentional to be a truly unique set up with a little amount of cuztom fab.
I bought a JDM GTO VR4 for exactly that purpose 12 months ago. Having had it for 12 months, there is no way im canibalising that car for the Daytona. It'll be caravan awd or rwd with r154
not sure if anyone threw this in yet....what about a talon awd system, wouldn't that transaxle bolt up to the 2.2 and 2.5s as well, and be very close in wheelbase too... my $0.02
I'm pretty sure that that is a mitsubishi setup, and wouldnt be compatible with the 2.2 2.5... unless it uses the 420A engine, then think you could make it work...
I've been thinking about this a lot too, what's making it more of a pain than say, an allardtom type thing with the RWD trans from a dakota??
To share an interesting analogy: A 3rd Generation Mitsubishi Eclipse with 6g7x engine was converted from FWD to AWD recently using a bellhousing adapter to run an Evo 8 drivetrain. This is a bit odd because while there are AWD setups that directly bolt up to 6g7x engines, those setups are from 3000gt's and locate the transmission on the passenger side (opposite from our style). Evo transmissions are on the driver side (balancing weight) and dodge friendly. Too bad the bellhousing adapter was a one off. My friend offered to do this for me but I declined based on wanting to do something more oddball.
This thread is opened in 2008, last reply was 2009, 6 yrs ago. The person you quoted last visit here was in 2011.
mmmkaycar is offline
Last Activity: 02-27-2011
As far as I know, there was no result from this thread. AKA, it's all talk, no go.
1987 Shelby GLHS #0958
Well, does anyone have any experience with the van AWD setup?
From what I can tell from pictures the transfer case resides where the intermediate drive shaft would normally be.
