thinkin the o p ment a msd ignition box - don't know about improvement on that
all turbo mopars have a rev limit and an over boost cut out
rpm limit depends on the computer in the car - I had two , one ran to about 5800 the other cut out at 7200
both worked in my 85 - I don't know what they were as they came out of 2 of the half dozz cars I striped parts out of at a couple local wreakers
as for the trans blowing , it depends - if it's an old sloppy puke trans it won't last long
I only ever had to fix one 525 'cause it ran dry shortly after I bought the car and the diff burned up , locked up and busted alot of stuff in the diff
I also managed to snap the 1-2 shift fork
this was a 305 final drive carb car trans - no hd parts 'cept the one shift fork
I replaced the fork with a brand new one for a turbo trans , replaced all 4 spider gears in the diff and the pin - which I peged in place with a roll pin from a dart steering collum , replaced all the bearings & races throughout the trans and installed a new set of the plastic pads that go on the ends of the fork fingers
I put it all back together with the orig shim for the input shaft under the snout the through out bearing rides on and that was that - other than filling it with 5w-20 motor oil
I never checked end play or run out on anything - everything was a little to tight - needed to use a ratchet to turn the input shaft with no other parts in the trans
when I started it , it ran slow for about a min then picked up engine speed as the trans was run into the specs it chose to run it's self
I blew 10 - 12 pounds of boost into the motor and NEVER had a trans prob in the 6-7 years I beat the livin snot out of it every day
it saw 7200 rpm severial times a day with a power shift here - there and everythere
only prob I had was keepin rod bearings in the 85 motors - that ended when I stoped useing castrol AND 85 motors
sorry if that seems to have turned into a rant - just gettin tired of the 525 bashin when I know I've made one work without any great effort
