2.2 no, 2.5 with no balance shafts-yes.tvanlant said:Doesn't the pan sit so low that the crank isn't even spinning in the standing oil? Most chrysler V-8s, the crank hangs low, somewhat submerged in the oil, making windage trays usefull, but the crank in these 2.2s is pretty well up in the block. No?
Here ya go; don't know about the steering wheels? (http://home.earthlink.net/~grant-racing/)MrBelvedere said:how about a link to grant racing and i hope they arent the ones that make the steering wheels
If thats a question, yes, just make sure to use the 2.5 oil pickup otherwise you'll starve the engine of oil!MrBelvedere said:thanks john for the link can you use a 2.5 pan on a 2.2 if they are both a common block
Sounds like a plan!John B said:I'm thinking a making a windage tray from expanded metal (wire mesh plate) and using the old balance shaft holes,bolts, and some spacers to mount it. What do you think?![]()
Moroso sells a one-way screen for $40.00 or so. It is a universal fit type of deal.John B said:I'm thinking a making a windage tray from expanded metal (wire mesh plate) and using the old balance shaft holes,bolts, and some spacers to mount it. What do you think?![]()
