Is there a replacement suitable for use on my 84 Daytona Turbo Z with Tilt Wheel??? It appears the eom unit is no longer available.
Mike
Mike
Do you mean the plastic piece that slips over the rod and controls the wipers and cruise control or the switch that's mounted under the dash on the steering column? this should be in the parts wanted section.
The plastic stalk that extends from the column that you use to turn on the wipers and operate the turn signals.
Thank you.
Old School Hot Rodder
If you have some way of reducing the size (I have Photoshop) then just select "image size" and change it to fit in the constraints here for size.
