I wanted to know if the engine wiring harness out of a 86 daytona with a auto
transmission would work in a 85 chrysler laser that is a stick shift,both cars are turbo?
Yes it will, BUT, you will have to make a couple of changes. You will have to change out the connector for the revese light switch on the trans. Auto's are 3 wire, manuals are 2. That third wire you will then have to run to a chassis ground or the car won't start.
I believe that is the major change, which is fairly easy.
