VOM = Volt/Ohmmeter
To check power output from the relay with the relay plugged in probe the output wire with the test lamp connected to batt - and turn the key to the start position, if the test lamp illuminates the relay and relay power/ground are ok and the problem is in the power wire to the starter or the starter itself.
I did this.The relay was bad.
I also bought new negative battery post because it wouldn`t tighten good.
Car fired right up after I put a new relay on.
3 seconds later smoke coming from the solid brown wire at the connector right behind the battery.The connector looked bad from being melted.I then replaced both connectors.
I also removed filter box and everything so I could keep an eye on the starter also.
My son fired it up and multiple big sparks come shooting out from around the starter.It then kept trying to crank even when key was pulled.I had to disconnect negative battery for the car to cut off.
I`m quessing now it`s the starter even though it cranked fine before and wasn`t making any strange sounds.
