It appears I was incorrect, it seems all tilt columns from 90-up are Accustar and non-tilt columns are Saginaw.
Unfortunately it also appears that none of the Accustar columns are serviceable and are not the same part # for all body styles.
The Saginaw on the other hand is completely serviceable.
From the 1990 FSM
1990 Dodge Spirit Tilt Column (Accustar)
1990 Dodge Spirit Non-Tilt Column (Saginaw)
I assume there is play in the column where the bad bearing is located?
If it is just a "rubbing" noise you are hearing when you turn the wheel it is the "clockspring", not a bearing.
My clockspring made this noise for ages, then it finally went bad/fell apart in 2014 (24 years), I found an NOS clockspring, installed it and the rubbing noise was gone, temporarily however, it did return and is still there.
