1 - 6 of 6 Posts
87 GLHS was running good but know I can't build consistant boost and the boost doesn't boost as fast. It also sounds like a blow off valve when I shift but I don't have a BOV.
Could it be the bottom intercooler hose?
Either intercooler hose will not affect vacuum but sure could affect boost.
R.I.P Dennis Jarvis
If you don't have a blow off valve and you hear what sounds like one then I say you would have a intercooler hose leaking or some where in the the are of where the turbo bolts onto the exhaust manifold.
Dennis
R.I.P Dennis Jarvis
I had a crack in the 'pipe' that runs thru my air filter box that caused my boost leak. Took me forever to find it.
Dennis
Legendary Driver
As Randy said it won't affect engine vacuum on a blowthrough setup but it will leak boost and overspin the turbo
1 - 6 of 6 Posts
