1 - 11 of 11 Posts
Need driver door window seat switch and turn signal assembly. Any help would be appreciated. Send pictures and shipped cost to Phoenix metro area.
Thank you.
What are you working on?
I do not have any but clarifying the vehicle will help others help you.
My 8 way power seat switch is also not working on some positions but I have never gotten around to doing anything about it.
What is the issue with the turn signals?
The pod switches have been an issue for years, however, the T/S switch runs through the headlamp switch, this means that the issue may not be the T/S switch, but could be with the T/S switch to headlamp switch connection/connector or the headlamp switch itself.
I was able to diagnose the circuit and repair a faulty ground circuit on the PCB.
If you like I can send you the TS switch diagnostics on Monday when I get home.
These are the part #'s I came up with for a 92 G-Body.
1)6 Way Power Seat Switch W/Recliner - 4373846
(Wing and Lumbar are separate switches located in the seat bolster)
2)2 Gang Power Window Switch - 4373359
(Power Seats and Windows are separate switches)
3)Headlamp Switch W/Foglamps - 4373696
4)Turn Signal Switch - 4565032
Part #4565130 is the Combo Window/Seat Switch W/Bezel.
Chrysler Parts Catalogs
1992 Catalog, Group 8 Electrical, Page 196, Figure 8-230 (Switches G-Body), Images D, G, M, P
1992 Daytona
SWITCHES
G-BODY
A 04373814 1 Back-Up Lamp, (Use Gskt. 1302807)
B 04687557 1 Door Pillar Front
C 04373331 1 E.B.L. (Heated Rear Window)
D 04373696 1 Headlamp, Inst. Lamp, Dome Lamp & Fog Lamp
04373504 1 Headlamp, Inst. Lamp, Dome Lamp, w/o Fog Lamp (Use Lever 4460178)
04373674 Glove Box
E 04443924 1 Ignition, w/Buzzer & Halo (Insul. 4419594) (Mtg. Screw 4326772)
F 04326603 1 Turn Signal Cancel & Hazard Warning
G 04565032 1 Turn Signal & Lane Change (Binicle) (Use Lever 5265737)
H 04373503 1 Windshield Wiper & Wash, Frt. & Rear (Binicle)
04373695 1 Windshield Wiper & Wash, Front Only (Binacle)
I 04565051 1 Door Ajar, Ind. Lamp (Insul. Serv. In Inst. Pnl. Harness)
J 04373696 1 Fog Lamp
05269267 1 Fog Lamp, EUROPE
K 04373552 1 Liftgate Open-Cargo & Dome
L 04373287 1 Dual Remote Mirrors (Use Knob 4373120) (Use Insul. 4439087)
M 04373359 1 Window Lift, 2-Gang (Use Insul. 4439088)
04373354 1 Window Lift, 1-Gang Rt. (Use Insul. 4419581)
04565130 1 6-Way Power Seat, w/Bezel
N 04373354 1 Door Lock, (Use Insul. 4439087)
04565130 1 Power Window & 6-Way Seat w/Bezel
O 04373678 1 Illum. Entry (Use Insul. 4504251)
P 04373846 1 Seat Adjuster, w/Recliner (Insul. Serv. In Wiring) 6-Way
04565130 1 Seat Adjuster, 6-Way Power (Insul. Serv. In Wiring)
Q 04373856 1 Lumbar & Wing Control
R 04565222 1 Security Alarm Disarm (Use Insul. 4400241), Right
04565223 1 Security Alarm Disarm (Use Insul. 4400241), Left
S 05252559 1 Security Alarm, Underhood (Use Striker 4373519)
T 1 Speed Control, (See Group #19)
04671019 1 (PRNODL) (Use Insul. 4638996)
04057750 1 Neutral Start, (Use Insul. 4419551)
05234319 1 Neutral Start, w/A604 Trans. (Use Insul. 4419551)
04565289 1 Headlamp Leveling, (Bezel 4685108) EUROPE
U 04672014 1 Clutch Interlock
1 - 11 of 11 Posts
