1 - 19 of 19 Posts
as the topic says, I'm looing to convert my '87 T1 into TII status while utilizing the same turbocharger.
Contact 86Shelby, I believe he still has mine. It's one of the cheap ones, but it does the job.
Discussion Starter · #4 ·
Keith Alto said:
Send me yours.
I'll convert it real cheap.
Then I wont be able to drive my car to work :p This work will be planned out over a weekend while I'm on my days off.
yeah I need an adapter too...but I think we all are going to have to suck it up and pay the $75 for the nice one on turbos unleashed...
-Lee
-Lee
Exactly. Once my turbo gets here anyway.
Has anyone done a performance comparrison between the cheap one and the pricy one from turbos unleashed? I find it hard to believe that it makes that much of a difference with that little turbulance created by the different size but does anyone have solid back to back results that show either way? This would be a great experiment for someone with both.
i don't really think that there is much of a difference from a performace standpoint, i think the cheap one is a little smaller, and just held on by the edges of the screw heads as opposed to being drilled properly for the bolt pattern. They're basically sending you a piece of a soda can with a lip on it ;)
And as the website says, it IS only a temporary piece.
I was wondering the same...but I don't want to take the chance of wasteing my time pulling the head and stuff, and using the cheaper one only to regret it in 6 months...so I'm probably going to go for the 75 one....If I had a welder I would attempt to make one...but theirs looks to be nicely machined and worth the money...
-Lee
I believe you can take a TI elbow, cut off the elbow part and weld a stub of 2" pipe in its place; this would be a trivial job for someone with access to aluminum welding equipment
if you want to minimize your downtime, buy a used TI inlet adapter and have it modded - then its a simple bolt-on;
you should be able to "clock" the turbo and do the inlet swap without ever having to remove the turbo / head from the car (depending on how small and talented your hands ar :)
PS I have a Brand New NOS TI inlet adapter I will let go for $15 shipped within US
It sucks that I have a Mitsubishi turbo laying around from a turbo one but with the newer intake manifold....so it has the proper inlet...I was thinking about how to cut off that pipe and rig something up...but I only have access to oxiacediline (sp?) and ark welders....And even to use them, I have to drive 45 mins to were my dad teaches a middle school hot metals class....anyway, like I keep saying, for people in my boat, its best to just bite the bullet and buy the damn thing....
-Lee
another alternative is to buy a TII compresor housing ; it will swap right on to your Garrett; they normally sell here in the 20-40$ range
however it would probably require you to pull the turbo to do the swap , but it may be posible to change over w/o pulling the turbo if you have a decent assortment of tools, small hands, and patience :)
I can send mine to Keith Alto in the post above, he can convert it for you, and send it to you.. little more time & shipping hassle but a simple bolt on procedure then for you
-Lee
Dont bother.
Guys there are plenty of people with screwed TO3 Garrets laying around off TII cars. The guys running Hybrids and bigger probly have 5 gallon pails full of old Garrets and mitsus...
Get the compressor housing and wheel and bolt it on.
Waramp said:
Dont bother.
but then your playing around with the alignment of the shaft correct? Anyway, its too late; I already bought the inlet adapter...I'm worried about how hard/easy it is to change the angle of the compressor side of the turbo...seems easy but I know how stuff like that goes.... :bash: :bang head
-Lee
-Lee
You may need a compressor housing gasket depending on the age and condition of your turbo. I will be sure to include one in at no charge with your TI/TII adapter. Positioning is all a matter of rotating the compresor housing until it faces forward without contacting the transmission or engine.
Chris-TU
Chris-TU
Well Chris, I happily purchased this turbo from you in 2003. So you tell me...do you think i'll need it?
With fine tip marker put a mark on the shaft, and wheel and nut, and be sure to index them at the same place. The nut should stop in the same place as before.
1 - 19 of 19 Posts
