let this be a warning to you all
i know some of the more experienced of you may not find this surprising or may feel that you would not have suffered the same consequences for whatever reasons, but i think everyone should be aware just how much damage an engine can suffer at 14 psi even with a big intercooler, about 11 air-fuel ratio, stage 3 computer and new injectors
1990 daytona es 2.5 turbo
hybrid T3/T4
grainger valve set to 14psi
big front mount intercooler (roughly equivalent to 3 stock cores)
+40 injectors with AFPR set to be equivalent to stock injectors
STAGE 3 fwdperformance 90/91 computer
innovate XD-16 wideband O2
stock exhaust
greddy type RS bov
rebuilt engine with less than 3000 miles
rebuilt swirl head with less than 3000 miles
stock timing
these were NEW cast mahle pistons
its not clear to me exactly when the detonation occured or why. AFR ratios consistently showed about 11 at WOT at 14 psi.
nevertheless, given that this computer still uses a 2 bar sensor (stock), whatever caused this happened below 15 psi for sure
my guesses as to what happened:
i had recently unplugged the knock sensor because i thought the computer was indicating false knock (for several reasons, this is detailed in another thread). perhaps the knock was real and this was the result.
i am using a grainger valve instead of letting the computer control the wastegate. see a recent thread where the pope discusses why this is not a good idea. perhaps this contributed.
my EGT's were probably above 1500F at WOT. its hard to determine this due to the slow response of my EGT gauge.
for a detailed thread on how i came to discover this piston had cracked see:
http://www.turbododge.com/forums/f4/f15/164157-aww-man-noise-head-block.html#post1271122
hybrid T3/T4
stock exhaust
greddy type RS bov
stock timing
