Got this thing over a year ago.
Long story short.
It sat 20 years in a garage so no rot but, the mice Destroyed the interior.
Got it running drove it back no heat gauges worst mouse smell so bad left top unhooked for ram air
Stripped out gross interior painted floors with Ace rust stop then installed red interior from a rotted 86 Lebaron.
Drove it weekly till winter so it won't rust.
Last week decided to start a T2 swap. This was Sunday.
Was thinking a few weeks to get it sorted maybe months.
Then Monday while cleaning the T2 Intake and exhaust manifolds Cop pulled up. He said people were complaining about cars on the street. (Condo yuppies don't think u should park outside ur own house) He said as long as everyone's plates/stickers are current no problems. said he'd be back Monday.
And of course the car with no head needs a sticker.
So in 90°+ heat trashed the Log junk. Not replacing that stud...
Cleaned assembled head,manifolds
Used a chunk off the old radiator
Nice fit
All assembled
Had a TON of issues but it runs/drives.
Downpipe flange is wrong so 1 side has a vice grip. (88 T2 Turbo)
Some head bolts didn't hit 90ft-lbs so swapped a few.
No idea what that radiator is from so zip tied for now.
Running 2 TB cable brackets.
Still using 86 T1 electronics 803 INJ
Next on the list is
Wire in GLHS LM and IAC+swap 804 injectors
Drill Downpipe flange to use spring bolts again.
Swap muffler for more flow.
Replace top (have it but all day job)
Replace HVAC box (still reeks of mouse)
Replace crappy aftermarket gas tank with non rusted stock one. (Stalls in left turns when low)
Swap O2 and add AF gauge
Redo brakes.
After all that next stage is
Ported head/2 piece
2.5 Bottom end ARP bolts
25+Psi on a Holset
Big injectors, custom LM, 3 Bar Map
Extra clutches in a large axle A413 (this still has the 86 small A413)
89+ subframe+ Big brakes
Better tires
Poly drivetrain mounts.
New rear springs.
Long story short.
Nice fit
All assembled
Next on the list is
Redo brakes.
Ported head/2 piece
25+Psi on a Holset
Better tires
New rear springs.
