89 Caravan heat/air controls
1 reading
391 views 1 reply 2 participants last post by  EvilcowRoland
#1 ·
1989 TI 2.5 auto.
The air shuts off when at more than about 1/4 throttle. It seems to lose control of the flapper valves that direct the cooled air. Seems like it defaults to the defroster ducts.
Where should I start looking for the problem?
It seems to me that it would be something in the vacuum lines.
Would I need to build a smoke generator to find the broken or cracked lines or fittings or is there a common trouble spot to check first?
#2 ·
There is a vacuum line running from the engine bay into the cabin through the firewall. This vacuum line will have a check valve on it so that once vacuum is drawn, it will stay that way on the cabin side. The line runs to the back of the heater/ac unit and allows the unit to control the vacuum valves for the air direction. Start by finding the line in the engine bay. It's usually on the driver's side of the vehicle behind the intake and under or near where the heater core lines pass through the firewall. Check this line for cracks or breaks all the way up to the heater control. If none are found, locate the vacuum check valve along this line and make sure it is only allow one direction of air travel and that direction moves air towards the engine. One of these 2 items is almost always the cause of the issue you describe. Post back with results.
