i noticed when i had my MBC hooked up and set to 12 psi, it would spool crazy fast.. usually faster than i'd like it to (when i was trying to stay stealthy around cops even driving slow, it'd spool like crazy and blow off stupid loud) well, i took the MBC out and its running off the factory wastegate actuator solenoid. i understand how the MBC and solenoid work,(bleeding off the boost till the desired amount is reached then cutting off the bleed to let the wastegate do it's job) i noticed with the more boost i run, the quicker the spool up. but my question is, when running less boost, is there a way to make it spool faster without increasing the boost?
