Spark Plug Gap
2.1K views 4 replies 5 participants last post by  guyd_15
#1 ·
I would like your recommendations on spark plug gap when I run the cold Champions (r n 9 y c) ? The normal plug I use is Champion (R n 12 y c) and I gap them at .035
Best Regards
BIG PSI
The ignition system that I run is an MSD Coil & 8.5mm Taylor Spark Plug Wires
#2 ·
Id run them as big as you can get away with without misfiring. Theres really no advantage to running a small gap if you dont need to (i.e. the ignition system cant fire it).
The only thing I can add is that at 32 psi boost, I had to gap my RN9YC plugs down to about 0.024" to get the stock 16V DIS system to reliably fire them.
#4 ·
4sfed4 said:
Id run them as big as you can get away with without misfiring. Theres really no advantage to running a small gap if you dont need to (i.e. the ignition system cant fire it). .
what he said.
I have never used champion plugs because where I go they don't carry them so I use autolite 64's (65 stock and they never have 63 in stock) plugs .035 is good till 16psi and then .028 is good till 25psi on my car with stock wires or 8.5mm magnecore wires it didn't make any difference. I run .030 just because I don't venture above 20psi too often, I also change plugs every 2k miles. $4.50 is a small price to pay to keep the car running top shape.
#5 ·
I gapped mine to .025, 22 lbs boost. Buy you've got plenty of ignition so you can probably open the gap up. I say start at .025 and keep opening until you detect a misfire.
Guy Douglas
