89 Dodge Daytona ES Need Replacement turbo
2 reading
4.2K views 11 replies 8 participants last post by  DirtyDuster
#1 · (Edited)
Hi all, I'm new to the turbocharged versions of the 2.2 and 2.5s, and I just purchased a 1989 Dodge Daytona ES 2.5l 5spd turbo.
The problem is that the seller 'neglected to mention' :mad: that the coolant lines to the turbo were ripped out leaving the turbo irreparable as far as I can tell.
In addition, there is on occasion a veery loud screeching noise that I think is coming from the turbo??.. :eek: (perhaps getting ready to lock up on me?-praying to the car-gods that its the turbo and not something inside the engine getting ready to flip out too lol...)
The turbo on the car right now is a mitsu, and I have new braided lines for it, but like I said, the turbos garbage now. I would like to get a turbo that is a direct fit. Maybe just another mitsu turbo so I can use the new lines or if theres something else you guys think I should consider.
The car only has 90,000 miles and I have no idea how the heck that thing got torn up like that.. (XP) Any recommendations about where to look for a ready-to-go turbo, and any tips/tricks to go about replacing the turbo on this car would be greatly appreciated. Thnx!
#7 ·
So the main installation difference between the garrett and mitsu being the hoses for the oil and coolant?
Also to replace the turbo, I'm thinking I will have to take the intake manifold and fuel rail off, can any of you guys with experience confirm this or enlighten me to any better way or trick?
#9 ·
although its possible to get the turbo off w.o taking anything off, I dont recommend it. LOTS of cussing will be involved... And goodluck getting the intake on and off. Sorry but the truth is the easiest way to change the turbo is to pull the entire head, turbo and intake manifold as one unit. Plus you can redo the headgasket, redo your gaskets and make it reliable. Otherwise, goodluck. A garret IS TONS better on a 2.5. Great upgrade. Spools better then when its on a 2.2 and all the sudden you will notice a MAJOR power difference in the upper end.
Plus with a garret you can run a 3'' exhaust with out having to worry about the boost control unlike a mitsu which loves to boost creep.
You can adapt the lines to fit on the garret but I would get a set of braided lines for the car for safety sake and longevity.
BTW welcome to the boards.
#11 ·
If you stay with the mitsu turbo it is not to bad to change just the turbo out. I just did mine on the 90 daytona. From under the car you need to unhook your coolant line and the oil return line. From the engine compartment you need to remove the throttle body for clearance and unhook the water and oil line. Then you can remove the v-band clamp holding the turbo to the manifold and manuver the turbo out the top. Oh yeah, either unhook the leaver on the wastegate or remove the two bolts holding it to the turbo. It took me about 20 minutes to pull mine and about 30 minutes to install it. If you have questions on this shoot me a PM. I do this stuff for a living and since I am basically lazy i tend to find the easy way to get things done.
#12 ·
Thanx for all the advice guys, my summer break starts in two weeks, since you can run the turbo w/o coolant lines, I'll keep driving as is, and then see about getting my hands on a Garrett and install while on break.
As a side note; I think the screeching was the alt, I replaced it late tonite an will be testing it tomm.. Sure hoping that was it.
