![IMG_7902[1].JPG IMG_7902[1].JPG](https://www.turbododge.com/d2/attachments/91/91442-3daaf1223c2e0091eb0e91a66e08f785.jpg?auto=webp&fit=bounds&format=pjgp&height=1920&optimize=high&width=1920)
My son and I recently bought a 1987 Dodge Daytona Shelby Z and while restoring it here are some of the common problems and the way we resolved them which could help others. These can be applicable for 1987-1989 Daytona Shelby Z and possibly other years and Chrysler/Dodge models.
- Engine Head gasket- All OEM head gaskets eventually fail on our turbo engines, currently there are a lot of bad replacement head gaskets out there and NOS is not good as it looses its adhesion properties. Some new current brands I found were Apex and Felpro version 5 (R5 stamped on the corner) with the reinforced corners (see other posts on this site).
- Noisy stock lifters- These engines are notorious for top end noise usually caused by the lifters. If you are running the stock lifters but they are noisy and the rest of the top end is fine, while you have everything taken apart you may want to upgrade to the PT lifters which require shims to make work. Others here (thanks, James, Bill and NAJ) on Turbo Dodge pointed this out to me after a year of restoration which in hindsight I should have done in the beginning when everything was apart.
Turbo Dodge PT Lifter and Shim Update - This is the popular Dodge and Chrysler 2.2 and 2.5 PT Lifter and shims upgrade kit that is a favorite performance enhancement in the 8 valve turbo dodge enthusiasts community. Here is a video of the replacment. - Engine Thermostat- our cars run hot, and it is best to drill a 1/16” hole at 12 o’clock location for many reasons. For example smooth continuous coolant flow, less thermal shock on the aluminum head and gasket when it opens, etc. Chrysler spec is 192-195 F thermostat. You can go with a cooler thermostat, but you are reducing the peak efficiency and performance of our turbo engine which may cause other problems.
- Radiator cap- there are a lot of new defective caps out there. AC Delco makes a good one. You can try Gates and Stant but check for it to hold pressure before installing. Even in a new box labeled Stant or Gates a different generic cap comes in the box from Rock Auto and Amazon. Two brand new ones I’ve gotten would not seal properly, one was missing an upper seal and the other had a wobbly top.
- Power Steering Pressure Hose- some aftermarket pressure hoses come misshaped or defective with a flare end that is too big and not flared correctly. It's hard to see it visually unless you measure it with a caliper measure tool. This causes the o-ring to expand just slightly and not fit correctly. My high pressure hose end was incorrectly made which expanded the oring 0.5 mm or 1/32” larger at the flare end, which tears the O-ring when inserting it into the power steering pump nut. If you tighten it enough there will be a metal-on-metal fit (bypassing the o-ring) but eventually that starts to leak from vibration. It's better to test everything and see how it fits out of the car before installing. Double check the fit of the pressure hose into the pump is good and the o-ring is intact by removing and looking carefully that the Oring is not torn or cut.
- Starter Motor- Because the starter is located right next to a hot turbo, they fail over time. While you have the top part of the engine head off, it is easier to replace it all when everything is apart. There are two types of starters that fit our cars. The starter with the NipponDenso solenoid is larger and last forever. The starter with the Bosch solenoid is smaller and easier to install if you have not taken the engine head off but not as durable. With either starter make sure to replace and install the starter insulation with the foil backing that goes around the starter to insulate it from the turbo. Our cars originally had it.
- Oil Pressure sender - they all fail over time. Replacing with the Standard Motor Products PS205 seems to fix the problem reading the correct pressure on the interior dash pressure gauge.
- Fuel Injectors – Most OEM Bosch/Mopar injectors fail over time on top of the injector leaking fuel onto the top of the engine. DblTrbl has a great post titled “Fuel Injector Warning!” write-up here with a list of all aftermarket injectors available for our high-pressure fuel injection systems, but most are discontinued. I would avoid a reman or cleaned OEM Bosch/Mopar design since they tend to leak. If you get a hint of fuel smell after a start up your injectors are leaking from the outside seam on top of the injector casing. I found the STANDARD MOTOR PRODUCTS FJ53 injectors are a better/newer design and works well.
- Front struts and mount kit – These parts are becoming scarce, got some NOS from Rock Auto which came in dusty old unopened boxes that were garbage. KYB makes new ones but even those could be a decade old depending on who you get it from. I found newer ones on Amazon, that were only 3 years old.
- Side window scraper weatherstrip- now that our cars are 37 years old, the outer side window scraper weatherstrip petrify, fall apart, and need to be replaced before it starts scratching your side windows. Rock Auto has the FAIRCHILD 11814 narrow weatherstrips to fit our cars. You do not need to take the windows out. By removing the interior door trim you can remove the scraper screws. To get to the screws I made a modified 90-degree Phillips head screwdriver (I cut and shortened a Phillips tip head and welded it onto a long handled thin flat head screwdriver making a 90-degree screwdriver) the trim can be taken apart.
- Sunroof outer seal- if you have a sunroof (not T-top) the outer seal deteriorates. An easy fix is to clean and reinstall a 10mm D-Shape Rubber Weatherstrip seal with 3M adhesive for the outer sunroof seal. An OEM seal is not available anymore and specialty auto websites charge a lot. There is a cheap $10 weatherstrip available on Amazon that works well and looks OE. See my separate post about this here.
- Front wheel wells rust and water leak- Our Daytonas have a weak point at the front quarter panel wheel wells. The plastic surround is about an inch narrow behind the front wheels and does not meet up with the metal wheel well behind the front tire. So, all the moisture, salt and debris that’s tossed gets caught in the wedge where the wheel well and the quarter panel meet. Eventually rusting out. On my car even the original seam was poorly constructed as there was two-inch-thick original sealant to cover the 35-year-old un-even weld. This leads to rust and eventually water intrusion behind the wheel well and onto the interior and floorboards at the front driver and passenger side of the car. If you want a dry interior this needs to be cleaned, sealed possibly welding with new sheet metal.
- Front windshield well (under the cowl) drive and passenger side leaks – As with any old car the body weld seams are all deteriorating and there tends to be a leak at both corners of the windshield well (under the cowl in the engine compartment). It is easiest to repair when hood is off, and cowl removed. By cleaning and sealing these seams the car is watertight again. I used Flex-Seal spray which has lasted thru a very hot summer and cold winter, so far.
- Odometer Gear replacement- If you are like me, I always reset my odometer to figure out my gas mileage. Pushing the reset odometer button while the car is moving is a big mistake on our Daytonas. The odometer gears deteriorate over time and by pushing the reset button on the trip odometer, breaks the gear. In the speedometer/odometer there are two gears a very small 20 teeth gear and a larger dime sized 16 teeth gear-pod. They both need to be replaced. The smaller gear was broken missing 2 teeth on mine and that stopped it from working, the pod was fine. OdometerGears.com has the gears and a useful video on how to take it apart. Be warned if you have a 1987 model year when taking the circuit board off to get to the gears, the stepper motor on the circuit board is not glued to the board as with other years and if it comes off it is almost impossible to reattach it. I made a post on how to fix the odometer here. Remember not to touch the trip odometer reset button ever again, at least not when the car is moving.
- Adding Remote Keyless Entry- If your kid is into electronics as mine... He wanted a keyless entry with remote since our cars did not come with one. It's easy to install by getting the DEI/ Avital # 2101 door lock remote kit, because it comes with built in relays for it to work on our reverse polarity power door lock system. You can get any other remotes but need to also build in the relays. I posted the installation blog here
- Pop-Up Headlight Module Repair (1987-89 Daytona) – Free fix- All Daytona owners are eventually going to have the pop-up headlight problem not going up and down. The problem is that the headlight module/relay is located in the car on top of the dash where it gets hot and bakes under the sun. The solder to the relays breaks down over time. The repair is basically re-soldering 8 solder points to make it work again. It is easy to get to by popping the top of your dash off carefully not to break any of the retaining clips. I used a wooden pop sickle stick to carefully wedge and pull up the dash. This is a common problem and others here on this website have a 3-part instructions blog which I added to here.
- Chrysler "Ultimate Sound System" Radio- the final repair project is fixing the original Chrysler Radio. The radio and display sometimes works but is out more often now that the weather is getting colder. When it does work the cassette works and the radio sounds great. Apparently my 1987 Shelby has the one called Chrysler "Ultimate Sound System" predecessor to Infinity built by Mitsubishi. Better sound than an Infinity I or II about the same as Infinity Gold radio. My radio’s display and FM tuner go in and out depending on the temperature outside. There is a fix on Allpar.com for this radio and other Infinity radios by taking it apart and re-soldering all the connections, but that will take weeks. Most Chrysler radios I have looked at from 1980’s thru 2000’s all have problems, typically a failed cassette mechanism and old/bad solder joints for the FM tuner and display. I have bought many rebuilt or supposedly "good" ones on Ebay, tried them out and ended up returning them since people can't seem to rebuild them properly. Update: gave up on fixing the original radio myself and just bought a new 10-band equalizer/CD/BT radio which was cheaper than most used OEM radios that eventually fail anyway.
- Remanufactured Front Brake caliper's copper washers are too thin and may leak. Forgot to add this since I had done it a long time ago. I ordered the Centric remanufactured front brake calipers and they were very good..., initially. When I was able to drive the car after the top engine rebuild the brakes leaked. I could see it was leaking at the caliper brake hose connection. Everything was new so I tightened it and the leak got worse. Luckily, I had saved the old calipers and washers. When I compared the old and new, the new copper washers were paper thin and the old copper washers were almost as thick as a penny. Because the remanufactured brake calipers mating surface was not smooth at the brake hose connection, the thin washer could not accommodate the uneven surface and leaked. Putting the original thick 37 year old copper washer worked and stopped the leak. Or make sure the caliper's surface at the brake hose connection is smooth before putting on a new bake hose line.
Update 2/4/24:
Very SAD day, finished our Shelby Z car restoration project and now drive it daily. Thanks to all the Turbo Dodge members for all your help. We couldn't have done it without all your help and advice.
Update 4/4/25
It's been a year since finishing our Shelby Z car restoration project, everything is working fine, not a single problem...yet. Over the past year my son used it as a daily driver, going to school, sports and has put over 5k miles on it. We got around 20-26 mpg fuel economy over this time, not bad for a 38 year old car. Now that he is off to college it's sitting around most of the time collecting dust. With the weather getting nicer I started it up and took it to a Coffee and Car Cruisin meet-up last weekend, it was a lot of fun. Our cars still get a lot of attention. It was parked next to a 1977 Ferrari 308 GTB and it got as much attention as the Ferrari, both with pop-up headlights. Our goal is to take it to the Carlisle Chrysler Nationals in July.
