Keith Black pistons? anyone use them??? how do they hold up?
14K views 28 replies 19 participants last post by  Gumpus
#1 ·
Just what the title of my post says...
Has anyone used the Keith Black pistons for their 2.2L or any other engine for that matter?
If so, how do they hold up and do they perfom well?
#2 ·
i ran them in all my na race motors but there's crucial setup required. ring end gap must be right on a couple thousandths less end gap and the ring can butt causing broken piston. also these pistons don't like detionation. don't take but a couple seconds of hard detonation to blow the piston top.
#4 ·
again, i guess u don't understand me. i used them in my race engines. these are 4cyl motors putting out 200-250hp non turbo turning 7-8300 rpm and compression ratios in the 12-14:1 range ( i built a lot of different race motors so i gave the range for many of them depending on track rules, engine type ford gm chrysler, import).
if u want a way better piston, then u need to go with wiseco, je, ross, mahle, or some other forged piston.
i picked kb hyper pistons because they were really light, really low cost and worked great for my racing applicatiion. i have failed a few over the years. partially based on my encounters with what i exactly told u the causes of failure
#5 ·
Of course the ultimate is to have forged pistons....I like JEs. I put KBs in my Daytona and ran anywhere from 12-16psi on pump gas and they finally gave up 5 years later when I sold the motor to my friend and he ran it for a while then decided to mess with the boost control lines till he said it was peging the VDO at 25psi. Really it was probably seeing about 28psi or so this was all on a 2 bar map MP computer.....it saw its fair share of 25psi and detonation for about a month till he called me and I had him put a stock computer in and hook up the boost control lines right. It ran that way for about 2 more months till number 3 burnt and broke the ring land out of it. The damage had already been done two months before.
Yes KB pistons can handle some abuse that is only if they are installed right. When you bore the block have your machinist bore it to the exact spec KB says and make sure your rings are gaped to there spec and they will live for a long time. If you bore it to loose and give them to much room to rock they will not last at all because hypereutectic do not grow like forged or cast pistons do and they will beat there selfs to death with even the slightest detonation if they are to loose. We are putting them back in that same motor later this summer when we put it back together. They all come weight matched with spirolocks, drilled oil holes, machined domes and all.
#6 ·
I am running keith black pistons in my 69 440 6 pack charger! They are awesome so far no complaints! We had the machine shop assemble the short block so its all correct and the car runs FREAKING SWEET!
Good luck hope this helps a lil!
The pistons came quick and were of great quality upon inspection before installation
#7 ·
keith black pistons are whats known as hyperreutectic alloy. ( i didnt spell that right) they are basically about the same as a stock cast piston, except they are a bit lighter, and the manufacturing process allows the company to make the pistons with less wasted material. durability wise, they arent any more resistant to detonation than a cast piston, prolly worse to tell you the truth. and when they let go they totally let go like allmotor said. they have a tendency to shatter under hard detonation versus just cracking.
if youre just putting together a mild N/A motor dont waste your money, just buy some cast pistons from a good manufacturer and you'll be fine.
#16 ·
I have a set of 2.2 Keith Black pistons I got from a member here a couple of years ago. I didn't use them, and neither did he (he got them from some one but never used them). The original user ran 22 psi, made good power and they lasted, but he also followed the clearance requirements and they held just fine. I they are for sale (really cheap) if anyone is interested. You may need new rings.
#21 ·
if you wana get silly with a N/A motor, id get some pistons made, forged, go with 13.5:1 comp ratio,H-beam rods, copper head gasket,studs everywhere, big cam, custom manifold that will hold a pair of either weber or mikuni carbs( one barrel per cylinder) fill it up with the highest octane race gas you can find and give 'er hell.
#24 ·
Well, hyper-eutectic pistons have their advantages--light weight, allows tight piston -> cylinder wall clearances, and low cost to name a few. They're pretty strong as long as you don't smack them with a hammer.
But if you want something more robust and more resilient to your accidental excessive ignition advance, boost spikes, and detonation or whatever, go with the Mahle piston for cost savings and forged if you want to beat the snot out of it. I wouldn't use them in this application. On a TBI engine, I definitely would.
I have a neighbor with a '69 Camaro that runs 11.6's in the 1/4 with Keith Black ~10:1 pistons. Its an all-out drag race car, so not a lot of actual miles on it. In 10 years, the engine has been apart once because of a valve float issue where the piston smacked the valve. The piston made silly of the valve.
This post has been deleted
