The car is a 1989 daytona shelby.
Started up the car after turbo rebuild and the car idles good, but whenever i try to boost or rev it to 3k, the car dies, almost like a fuel cut/rev limiter. I looked at all the sensor outputs on my old OTC and everything seems to be in range and moving with rpms. I have the follwing codes: 12, 13, 14, 27, 37. 12 is NBD, i know 13,14 is map. 27 i believe is the inj 1 ckt. But 37 i couldn't find in my book. My charge temp sensor reads at the rail of 262* even when cold. Could this be causing it? Once in a while the car will drive And boost up ok, but majority of the time the car acts up. I will try another map sensor, but i saw that the conector is different. I have reset all the codes and then when i start up the car, i get 12, 13 and as the car runs the rest of the bunch.
Any input is appreciated
Thanks,
Thanks,
