181 - 183 of 183 Posts
I guess I learned a different kind of math. I can buy 2 OBX LSD's for the price of one peloquin. I am still looking for a spacer or the plans for one. I am going to buy an OBX and put it in my A413. If I have to figure it out after I get the OBX lsd I guess I will. I repeat.
If no one sells one, where can I get the plans for one? If someone has one for sale, pm me or email me at jmanpt@iland.net Thanks, Pat
buy the larger bearing cup from the neon. Then run the bigger Neon bearings, either way you need new bearings. Then the new shims and misc hardware. Then you need to mod the case and make a new cover plate to use a OBX in the 413.
Vs buying it all in a package that fits for $1,000 :shrug: Yeah a couple hundred more maybe but worth that for the trouble. :rolleyes:
almost for got you need to buy new washers and fasteners for the OBX. Then machine the axle holes to make sure they go in. The OBX is worth it for a 5 speed, but the 413? Not hardly
Man, I haven't been on here in ages.
BUT.
It just so happens I took the turbo Neon off the road this past summer and began to disassemble it. After having a baby things have changed and the Neon isn't really a priority anymore.
I happen to have a spacer both cups, and a modified diff cover from my old Quaife setup I was running. If you are still looking for the spacer and related parts let me know. I may also have shims and such in my trans parts bin.
Two more reasons to buy Peloquin.
I've broken 2 trannies, but never had a problem in my 9 sec Neon with the Peloquin.
Kevin McNatten has broken countless trannies and never had a problem with the Peloquin in his 8 sec Neon.
