Hey if you get to post a list so do I! I think i've already posted this on here a year or so ago, but since its relevant to this thread and may help someone, heres my head removal instruction list for a 90 daytona 2.5 turbo, but its an upgraded turbo (stock manifolds though). (i also have an engine removal instruction list if anyone wants one).
STEPS TO REMOVE CYLINDER HEAD WITH MANIFOLDS AND TURBO ATTACHED
ABOUT 2 HOURS
DRAIN COOLANT
move car to location where coolant can drain
disconnect lower radiator hose from water pump
remove radiator cap
let coolant drain (dont need every drop out)
disconnect heater hose tube from bottom of water box (channel locks)
disconnect upper radiator hose from thermostat housing (medium flathead)
once coolant has drained place tube back on water pump to keep further coolant from leaking out
remove dipstick retaining nut and swing dipstick bracket off the stud (3/8" wrench, 1/2" socket, 3/8" short extension)
remove dipstick and dipstick tube
loosen throttle body hose clamp and pop off throttle body air tubing
loosen clamp at air inlet of turbo and remove air filter tubing
loosen clamps at turbo output and swing j bend out of the way
disconnect ground strap from head near airbox (1/2" 3/8" socket and 3/8" ratchet)
unplug spark plug wires from plugs and center wire from distributor
disconnect coolant sensor on waterbox
disconnect coolant sensor near #1 cylinder
disconnect brake vacuum line from intake manifold (large channel lock pliers)
disconnect vacuum manifold from intake manifold
disconnect vacuum line from AFPR
disconnect AIS and TPS connectors and remove harness clip from throttle body (needle nose pliers)
disconnect throttle cable from throttle body (large channel lock pliers)
remove bolt from gnd strap and o2 sensor harness bracket from rear of intake manifold (1/2" ratcheting wrench)
remove grainger valve and tubing
remove 2 fuel injector rail bolts (3/8" socket wrench, 10mm socket, 3/8" long extension)
remove fuel rail/injectors from intake manifold and cover fuel injectors with trash bag
unplug knock sensor
**** as needed
put transmission in neutral
rotate engine to TDC via camshaft bolt (18mm socket, 1/2" socket wrench, flashlight, use flywheel marks)
verify camshaft sprocket timing is correct
detension timing belt and remove from camshaft sprocket (loosen tensioner nut with 15mm ratcheting wrench and wooden block from above)
remove EGT probe (.075" / 1.8mm short allen wrench, do without gloves, loosen as much as possible on first try, may get stuck)
remove upper 2 ac compressor bracket bolts (15mm ratcheting wrench)
jack passenger front side of car up high
remove turbo air scoop (3/8" short extension, 3/8" ratchet, 10mm socket)
from under the car, remove two bolts holding exhaust downpipe to swingvalve (1/2" ratcheting wrench, allen wrench, adjustable crescent)
remove two bolts from turbo oil drain tube flange (3/8" socket, 3/8" short extension, 1/2" 3/8" socket, 1/2" crowsfoot)
remove turbo to block bolt (on turbo side) (15mm 3/8" socket and 3/8" ratchet)
place large pan to catch coolant under turbo coolant line
loosen turbo to block coolant tube nut (11/16" wrench), LOTS of coolant will flow out
disconnect turbo oil feed line from block oil manifold and cap tube (9/16" wrench)
remove valve cover (3/8" long extension, inner 5 with 10mm socket, outer 4 with 1/2" deep socket, drill + adapter)
remove head bolts AND washer (1/2" breaker bar, 15mm socket, 1/2" extension, drill + adapter, magnetic pickup)
lower car off jack stands
place gray mat on passenger front corner of engine compartment, pushing hood pin through mat
put on thick gloves
remember to keep hood seal out of the way of intake manifold
place right foot on drivers shock tower and left foot on radiator crossmember, lift head off and put on mat then to floor
