Turn signal stalk won't stay clicked to the right
8K views 6 replies 6 participants last post by  saw wave analog
#1 ·
It's kind of a wierd problem, I have no idea how to fix it, my turn signal stalk won't stay clicked on to the right. It'll stay down on the left but not on the right. How do I fix this issue? :bash:
#2 ·
Replace the turn signal cancel cam, you'll see it as soon as you pull the steering wheel.
-Chuck James
#5 ·
Check some of your local parts stores in the Help section. They shuld have a Chrysler turn signal repair kit. It is the top part ofthe switch and contains the locking tabs that hold the switch in the turn position. If you have cornering lights like mine, you will probably have to go to the dealer or a junkyard.
#6 ·
how's your alignment? If the steering wheel is off the turn signal won't stay locked over. But yes, just pull the steering wheel off, then you have to fit with a locking clip, dig that out and don't worry about putting it back. and under there you'll see the turn signal guts. It's fairly easy to see how it works.
