I've got a very small crack that I'd like to patch. Would rtv or epoxy work?
well you are kinda right, they ARE different. Aftermarket parts are gay. I spent 3 weeks one time to get back an axle for a spirit 2.5 sent out as a core. I had to have it 'made' at a shop. That was a long time ago, i learned my lesson. Even the mopar books aernt always right. I just give the aftermarket companies an OE number to cross and they are like that doesnt fit that car. Uhh yea it does. But yea the manufacturer DOES matter. I had a Caravan one time that spit 4 axles, didnt even make it off the lift, and come to figure they all were car axles, from Carquest (reman).BUBBA said:Well, it's funny you mention this. The last axle I got looked a little bit different from the previous 2. There's no way to specify which axle style I want/need at the parts store. The axle manufacturer shouldn't matter so long as it's made for the same car and the length is the same.
Well if it works for you cool. You are talking to a 'dealer'. Most parts guys just say no its ns1 cause they are to retarded to find it in the catalog.phantomrt said:According to the books and the dealer, the car in question only came with one style of axle. I know that in the 80's same year, same make/model, same engine, same transmission, different style axle, which is why they usually ask what brand of axle you have. To my surprise, question was never asked when I went to get the boot for the car in question.
According to the diagram above, it has to be the ACI axle I was working with, going by the tripod-shaped inner joint housing. The original mopar inner boot is a 2-piece design. Aftermarkets are 1-piece. The boot from NAPA works fine on the passenger side because there is no transmission housing to hit.
Yea, I can second that. Been there many times.jdawg said:Well if it works for you cool. You are talking to a 'dealer'. Most parts guys just say no its ns1 cause they are to retarded to find it in the catalog.
I was at a car show earlier this year and a kid had an L-body with an aftermarket axle in the passenger side. It had the ABS reluctor or whatever on it. I don't think it was supposed to fit in there, but it was in there and it looked pretty beefy.BUBBA said:Does anyone make stronger aftermarket axles for our cars?
RampageTurbo said:How are your motor/tranny mounts? I had a minivan blow out a couple of tripod joints before I figured out that the flexing of the motor and tranny mounts was the biggest contributor to the problem.
Hi allmotor, I am willing to spend the 20.00 SO WHAT IS THE CORRECT BOOT, toddallmotor said:an outer CV boot can be easily replaced ,on any td, with the correct boot for under $20 and 20min of you time. so what's the big deal? why replace the whole shaft?
oops, I forgot, its a TD so therefore $20 just might break the bank.
Just when is it possible to reach the member called" allmotor "to get some o f his "great advise" not by email what is the dealtodd peterson said:Hi allmotor, I am willing to spend the 20.00 SO WHAT IS THE CORRECT BOOT, todd
Many times people dont notice the rips until they have lost grease, in which case may have worn down the internals a bit or scored them.allmotor said:an outer CV boot can be easily replaced ,on any td, with the correct boot for under $20 and 20min of you time. so what's the big deal? why replace the whole shaft?
I registered only to reply to this ...silly comment from 2006. How do you estimate it takes ONLY 20 minutes to replace a CV boot. You must be an alien with supernatural skills or perhaps you are Superman himself! Some people are UNBELIEVABLE !!!It just might but for the hassel, should just put on a new one. Do it right the first time, no prob's later. Plus, it's only going to get bigger and it would take you like, 20 minutes.
