Digi-Key is pretty awesome (but so is Mouser) I ordered the USB to RS-232 (in a single cable connector with wire-ends) and the TINI Q-G (TA4FL) connector last Friday and it arrived Monday.
Here's a tip, scroll down when selecting the shipping to select the cheapest option by US Postal service it doesn't say it but if the package is light enough they'll nearly ship overnight.. just no guarantees. Still arrives in a well padded cardboard box or envelope in your mailbox.
This morning I took a few pictures and struggled with how to pull it apart and assemble it.
First here's what the mini-XLR looks like next to the PC/Printer plug on the DRB-II
And securely inserted
Next here's what the mini-XLR looks like next to the PC/Printer plug on the OTC4000E
Removing the mini-XLR insert is very difficult and isn't described anywhere, here's how to do it, get a plastic pen
And use it to shove the insert backwards
It comes out and then falls apart into two pieces
I wouldn't worry after its assembled and the strain relief handle is screwed back on.. that should hold it in place, there is also a groove you can't see to properly align it in the housing with the quick release button on the side
The completed cable is a bit of an upgrade from 1988
This cable should have all the parts to connect to a modern USB 2.0 port on a PC and communicate natively with the DRB/OTC using RS-232 signals (beware that TTL RS-232 is not the same thing.. that was invented much later to be used with very small electronics and runs at smaller communications voltages.. this cable is different.. it runs at higher communications voltages and is deliberately "old school" compatible with traditional PC peripherals).
The Digi-Key cable here made by FTDI is something of a marvel.. I hope it works.
I have been reading the 1991 training guide for the DRB-II and it says the [Remote Connection: On] feature was intended for displaying menu options on an instructors screen and would significantly slow down the display of values.. bummer.
Still I plan to pursue it just to see if the GTC software can download recording sessions where the data might be captured faster. And perhaps the OTC4000E has improved software that overcame that. The OTC4000E seems somewhat superior in some ways. But it can never replaced the DRB-II because that is what the Powertrain manual and Service guide for the Light Weight Pickup D250 calls for.
However the OTC4000E was made by the same company that made the circuit board in the DRB-II and externally they are almost identical. (note: the cartridges are not interchangeable if only because the OTC4000E PathFinder-II and PathFinder-III cartridges are smaller in size and shape. The DRB-II cartridges are larger. The number of pins on the cartridges are different as well, the DRB-II cartridges have more pins.)
I'm sort of learning that the electronics in these "data readout boxes" or "monitors" was really slow relatively speaking.. and that could be why the DRB-II included the big red Volt-Ohm-Meter (VOM) connector on the top right.
The theory back then seemed to be.. that to "truly" test a sensor or other voltage varying device.. the digital data was either too slow or insufficient. So having a Digital VOM in the same device was convenient and handy. I also imagine it was useful when tracing out ground faults or short circuits. And digital "anything" in 1988 was kind of futuristic... lol.
[Footnote] The USB cable connector is "Clear" or "Transparent" because its suppose to have a red and green LED on the tiny circuit board that light up to indicate traffic.
