First Batch coming out. Going with twelve longer bolts
Bill Reichert 35 years servicing and restoring pianos. Thanks for the help. Actually I messed up my first set of piano keytops when I was 12. That's 50 years ago. The garage I use has two grandsons in high school training. They will be the fourth gen to service cars.David Rose said:Shimming the spacer will not help bearing preload.Preload is adjusted from the left side bearing support under the cup.So you only need to pull out the seal and oil slinger puch out he bearing replace the shim.Reuse the bearing and slinger replace the seal.Oh ya 26 years Chrysler auto tech last 18 years trans rebuild experience.Hope this helps
You still have to use the stock bolts where the clearance issue is. The cap heads go inside. You might as well use what you have. After you torque the bolts final time. I think grinding the bolt head for final clearance is the best way to go. If you have to remove the bolts later, you have a very serious problem already with a blown obx. In other words, it's already wasted.MooseMotorsport said:Ok, so if I were to send my spacer back out to have 12 more holes drilled and tapped and had the existing holes counter sunk and ran the 24 stock bolts I won't have to grind the case down at all? I've already got 23 stock bolts, I've lost one but can easily get another one.
And how much do your spacers cost if I don't feel like sending mine back out?
The spacers are $60.00 each. If anyone wants one, PM me. I am finishing the mill work on them this weekend. So far there are 3 sold to DBLTRBL, 2 sold to looneytuner. There are limited qtys for now, like 11 or so left. Next up are the diff cover spacers.MooseMotorsport said:Ok, so if I were to send my spacer back out to have 12 more holes drilled and tapped and had the existing holes counter sunk and ran the 24 stock bolts I won't have to grind the case down at all? I've already got 23 stock bolts, I've lost one but can easily get another one.
